Corvette Servo/ Transgo Questions
Old Jan 1, 2001 | 02:42 PM
Shane88GTA's Avatar
First,are there different stages of shift kits available from Transgo? Second, does the Transgo kit(s) use the vette servo and other vette parts? Along with the Transgo kit, I want to use vette servo(piston and housing, and of course seals for housing and cover), the vette TV boost valve, (possibly the intermediate/reverse boost valve, found at www.pro-built.net), the vette pressure regulator spring, and the vette 3-4 upshift sleeve. So I need to know what the Trangso kit consists of so that I can get the other parts I want that are not included. Also, in the probuilt catalog, they state that their corvette servo has been "machined to alleviate 3-2 clunk, 2-3 clang & cutloose and 1-2 slide." Do the original GM units produce these problems? Thanks for any help.
Old Jan 1, 2001 | 03:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If I remember correctly, you choose the "personality" of the kit when you install it. I don't think it includes any of the other parts you're talking about. You could always get the kit and look inside before you get the rest of the parts.
I'm using the original GM Corvette servo, and I don't have anything that I'd describe as "3-2 clunk, 2-3 clang & cutloose and 1-2 slide".
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
[This message has been edited by Apeiron (edited January 01, 2001).]
Old Jan 1, 2001 | 03:57 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
My car lugs into third if I'm not on the gas, but other than that, it shifts great. I don't know about the other "problems" they sound like some kind of dance moves.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
