T-5 noise and ????'s
Old Dec 30, 2000 | 08:54 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I just installed a B&M shifter on my T-5 in my '90 Iroc. Now when the car is cold and I put it into 5th, there's a noise, sounds like a syncro noise. Once everything is warm the noise virtually goes away. After hearing this noise, I realize that it was always there, but it was very faint (I'm guessing because the stock shifter was insulated better to reduce noise). I'm wondering if anyone has any suggestions as to what's causing this noise, and I guess since it's always been there, it should be safe to use 5th once everything is warm right? Thanks for the help.
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd (no mods...yet )
Old Jan 1, 2001 | 08:40 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
The same thing happened to me so it is normal you just have to live with it!! Yes the Ripper transfers more noise than stock and it can be annoying.
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.73 @ 95... traction still a problem
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
DARKmj16
Sep 9, 2015 04:07 PM
Randomtask2
Sep 7, 2015 05:06 PM
