Clutch wont engage?
From: First one out of liberty city, burn it to the ground
Clutch wont engage?
ok today was the first time i tried to start the car and shift it into 1st... i went under the car and put it to where the clutch SHOULD have engaged..went in the car to put it in first and it still wont go into gear...why? anyone have any ideas?
89 Firebird
2.8 V6 w/ t5 tranny (383 tpi t56 w/ ati 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
89 Firebird
My Site:
anyone help?
89 Firebird
My Site:
89 Firebird
My Site:
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Could be your slave cylinder ear broke and it's not pushing in the clutch fork.
That is what happend to my car about 2 months ago. It got harder and harder to shift into any gear. Then I got stuck at a stop light cuz I couldn't get the car into any gear. I finally slammed it really really hard into first and was able to pull into a parking lot and get the car towed home. The slave cylinder is under the car right in front of the drivers leg area next to the transmission. Look under there and see if the slave cylinder is still in place or if it is crooked. The ears where the bolt goes through is plastic, so this could be a fairly common problem on older cars.
The part was less than $20.00 and took about 30 minutes to change.
After we changed it and filled the resovoir with fluid I pumped the clutch and there was no pressure. The next day while I was trying to remove the clutch master cylinder(which I thought was not working anymore) I suddenly got pressure in the clutch. Been working fine since then.
Hope this helps you out.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
