3/4" Clutch Master Cylinder
Old Sep 14, 2008 | 02:00 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
I want to put a hydraulic throw out bearing in my 5 speed 89 camaro and I’ve read that it needs a 3/4" bore clutch master cylinder. I was wondering what the stock bore is for the master cylinder for the t-5 is, maybe the master from a t-56 car would have a bigger bore? Or if i cant find a stock clutch master cylinder what aftermarket master would work.
would this work? http://www.jegs.com/i/Tilton/454/75-750U/10002/-1
Thanks!
Old Sep 14, 2008 | 03:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 3/4" Clutch Master Cylinder
3/4 is a smaller bore than stock, and a smaller bore is more "performance app" than a larger bore. I think the the ls1 masters are 3/4, or just a hair larger. 98-02 cars use a hydraulic TO, so i dont see why a master form them wont work. Its almost a complete bolt on too, just a little tweaking fo the brake lines
Old Sep 14, 2008 | 03:31 PM
heff17's Avatar
Car: 89 Camaro
so does that mean i can use my stock t-5 master with my howe hyd TOB?
Old Sep 14, 2008 | 07:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im sorry, my bad, i misread what was asked, i was thinking brake master
AFAIK the clutch master is the same, 4th gen to 3rd gen, they will interchange too. I dont see why it wouldnt work, but i havent tried it.
FormulasOnly
Jul 23, 2018 08:47 AM
camaro1185
Oct 26, 2015 06:51 AM
meeklay812
Oct 1, 2015 03:46 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
mfp189
Sep 27, 2015 09:25 AM
