Rock Crusher
Old Jan 4, 2001 | 10:52 PM
86_327_camaro's Avatar
Rock Crusher
does anyone have any idea how hard it would be to run a rock crusher with the torque arm. also what would have to be done as far as bellhousing, transmission mounts, etc...?
Old Jan 5, 2001 | 01:32 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I'm really, really, really sorry to say this, but, the only way to use it would require alot of modifying, and complications.
Just get a WC T-5. Alot easier.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Jan 5, 2001 | 07:21 AM
Cowboy's Avatar
Get a Spohn Torque arm cause it mounts to a new crossmember instead of the tranny. Make sure you have all the dimensions for him but it should be the same as an '82 4-speed.
Now the next problem is manual linkage since the only thirdgens to have that were '82s and '83s.
If you have the opportunity to look at an '82 with a 4-speed you should notice that the shifter is mounted to a bracket that attatches on the passenger side of the tranny to get the shifter and it's linkage away from the torque arm. Nothing like this is available for the M-22 to my knowledge. Depending on what the car is to be used for, it is probably not worth the effort.
I may use my M-22 one day in a Big Block drag car situation but certainly not for a street toy.
Hope this helps
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Thornburg
Aug 25, 2015 01:46 AM
neekolzun
Aug 24, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
