Attn: TomP
Old Dec 15, 2000 | 09:13 PM
irocbsa's Avatar
Attn: TomP
When we were discussing your ingenious bearing puller and doing the rear end swap you said that you plugged up the brake lines at the junction block on the axle. I have tried to do this several times but the damn thing still drips fluid. I can't get it to stop dripping entirely unless I put the lines back in. I wii\ll need to have the thing plugged for a while b/c I want to swap some stuff from the old rear to the new one. Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Jan 5, 2001 | 09:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
While doing a search for something else, I found this... sorry I didn't see it earlier!
I never plugged my back line on my swap. It could be done though by cutting your old body-to-axle brake hose in half. Then you'd screw a bolt into the end of the rubber hose. Your current body-to-axle brake hose should be replaced by now anyway; it's surely deteriorated.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
fasteddi
Sep 10, 2015 09:32 AM
squirrelybird
Feb 19, 2003 08:25 PM
loomdog32
May 1, 2002 10:21 AM
CaliCamaroRS
Mar 12, 2002 12:08 AM
