Attn: TomP or anyone else
Old Mar 10, 2002 | 07:02 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
TomP, I'm almost positive you know the answer to this.
I'm having some flywheel issues( with my PITA T5 swap) and I wanted to know the difference between an 86- earlier and an 87-up flywheel. I have 1 of each, my '85 flywheel has a fat weight on the back and my '88 doesn't.
Sooooo, are the early 6ers externally balanced and the later ones internally balanced?????
Old Mar 10, 2002 | 09:59 PM
Camaro_hunter_d's Avatar
I have a 92 5 speed. No weights. Neutral balanced.
Old Mar 11, 2002 | 02:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, you got it, Dan. 1987 was when the 2.8's in the front wheel drive cars received the distributorless ignition, and used an extra crank counterweight to hold the timing signal. The '87 rear wheel drive 2.8's inherited the counterweight, but stayed with the distributor. The counterweight allowed GM to internally balance the engine.
So 82-86 2.8's are all externally balanced on the flywheel. All 82-92 2.8/3.1 (and maybe the 93-95 3.4?) balancers are neutral balanced.
As to what you should do, I have no idea. Let me know what you come up with, though!!
Old Mar 12, 2002 | 12:08 AM
Engine: LH0 3.1L
Thanks guys. I guess i'll be using the '88 flywheel I have. The '85 will get junked unless anybody wants it........
fasteddi
Sep 10, 2015 09:32 AM
squirrelybird
Feb 19, 2003 08:25 PM
loomdog32
May 1, 2002 10:21 AM
RenoLB8
Apr 6, 2001 03:43 PM
