AHHH Tranny fluid leaking from T-56
Old Jan 3, 2001 | 11:04 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
It was fine for the first 2 days but now my tranny is leaking fluid quickly. It is coming between the tranny and bellhousing. maybe the input shaft seal has busted?? If so how could this have broken, how hard is it to fix? Also I had this transmission gone thru when I bought it could this have been cause by incorrect installation or would this must have been something there before?
91 Z28 5.7l Camaro
T-56, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Jan 4, 2001 | 03:07 PM
Car: 1991 Z28
BTT
Old Jan 4, 2001 | 03:37 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If you converted from a manual did you put a pilot bearing/bushing in?
If the women don't find you handsome they should at least find you handy
88 GTA Notchback with 91 gfx and ROH Snypers
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Jan 4, 2001 | 09:30 PM
Car: 1991 Z28
yes I did but it wasnt an easy fit so i got it as far as I could and we put the bolts in and then tightened them in a cross pattern and it forced the input shaft into the pilot bearing. but it is in there. how would it cause a transmission leak.
Old Jan 5, 2001 | 10:34 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I just wondered if you had or not. If you hadnt I was going to suggest that could have made the input shaft to bend causing the leak. Sorry though I cant answer you question. But I would venture it is the front seal. I have no idea how hard it is to change either.
Old Jan 5, 2001 | 11:53 AM
CamaroZ_85's Avatar
ive never done a front seal on an auto or manula but i think you just have to pop it out...it should be right there, where the input shaft goes into the case
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Jan 5, 2001 | 04:08 PM
Car: 1991 Z28
does anyone know how i could have caused this?
91 Z28 5.7l Camaro
more to come....
My 91 Z28
tonys91rs
Oct 10, 2015 03:31 PM
Stryker412
Sep 20, 2015 06:59 PM
bubbaz28
Sep 18, 2015 02:09 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
