1992 trans in a 86 iroc
Old Jan 4, 2001 | 11:23 PM
zee28's Avatar
Car: 86 iroc
will this work right? ,I assume it will,I was just wondering about computer,and electical connections to trans.
~mike~
1 superclean 86IROC-Z
Old Jan 5, 2001 | 12:02 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
zee28,
Congratulations on getting a hand on a 92 700r4. It is a much stronger tranny and will definitly work on you 86 IROCZ. You may have to change the yoke on your drive shaft since the 92 tranny have the 30 spline. The 86 driveline has the 27. Check first, I maybe wrong but I just did a tranny swapp 2 weeks ago and we had to swap out a 27 spline yoke for a 30.
Old Jan 5, 2001 | 08:34 AM
zee28's Avatar
Car: 86 iroc
so the yoke can be changed?
~mike~
Old Jan 5, 2001 | 11:36 AM
Blade's Avatar
Of course it can be changed.
Old Jan 5, 2001 | 11:55 AM
CamaroZ_85's Avatar
the 92 tranny will also have an electronic speedo sensor while your car came with a mechanical speedo. you could either switch speedometers...or maybe swap the tail off your old one...if thats possible on an auto trans
Old Jan 5, 2001 | 12:00 PM
Gta-Paladin's Avatar
What tranny do i have in my 89 Gta Trans am?
(l98)
Old Jan 5, 2001 | 12:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Paladin: 700R4
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 6, 2001 | 03:21 AM
Danny P 86Z28's Avatar
I put a 90 tranny in my 86 and had no problems with the driveshaft fitting.
Old Jan 6, 2001 | 10:13 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Its not the yoke that has a different spline it's the converter= '86 has 27 teeth-'92 has 30teeth.
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd (now TPI)
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Old Jan 6, 2001 | 11:00 AM
zee28's Avatar
Car: 86 iroc
Dyno,that makes sense.so the yoke doesnt have to be changed.just the converter,right?
~mike~
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
