Did anyone go from 3:23s to 4:11s ?
Old Dec 30, 2000 | 03:07 PM
Blade's Avatar
I can buy a whole 92 rear-end with 4:11s in it for 100 bucks if I pull it. Did anyone go from 3:23s to 4:11s ? How much of a difference does it make ? THanx
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 1, 2001 | 07:33 PM
BlueBottleJunky's Avatar
Blade, when I went from 2.77s to 3.73s, it made a ton of difference. Obviously the lower gear(higher numerically) would respond well to intake mods. I've seen articles where 2.77 gears have a lower ET and higher MPH than the same car with lower gears on stock TPI motors. Thats obviously not the case in a car that has an ugraded intake setup(mini-ram or super ram). So, in short, if you're running a stock TPI setup, I would stick with the gears you have. If youre running a good aftermarket intake setup, you'll be greatly rewarded with the rear gear swap.
Old Jan 8, 2001 | 11:20 AM
Tadder's Avatar
I have '89 Iroc that I made the switch in. I went from a 3.08 to 4.10. Night and day difference. Changing the rearend gear is by far the best bang for the buck.If you have a 5-speed it is even more fun.
Old Jan 8, 2001 | 12:29 PM
FastBroker's Avatar
Will get you into the high 12's EASY IF you can hook-up the tires. Make sure it is posi or put a posi in it. If you don't, you will be one-lighting all day with those gears. Will need sticky tires if you don't already have them.
Plus, if you don't like it, sell it for $125 bucks... Heee hee
[This message has been edited by FastBroker (edited January 08, 2001).]
Regal105
Aug 23, 2015 03:45 PM
vortech305
Apr 25, 2001 10:06 AM
rusty Z
Apr 3, 2001 02:11 PM
rusty Z
Feb 5, 2001 12:26 PM
G
Nov 19, 2000 08:38 PM
