Water in Trans?
Old Jan 7, 2001 | 01:23 PM
dan92z28's Avatar
Water in Trans?
Recently my car has been in storage when i checked fluids all checked out except for the trans fluid. It looks milky/whiteish some 1 told me its water another person told me that it could be antifreze. Has any one had this problem before? I dont know what to do. Any help would be greatly appreaciated.
Old Jan 7, 2001 | 02:51 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Sounds to me like the tranny cooler part of your radiator is leaking. That's the only way I know of for water/antifreeze to get in the tranny fluid, other than intentionally dumping it in there...
KAM
Old Jan 7, 2001 | 04:04 PM
Fastcamaro87's Avatar
check your antifreeze and see what it looks like, if its messed up to looks like your tranny cooler went south.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Jan 7, 2001 | 04:48 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Whatever it is, find out and fix it, then change your fluid, twice!!!
If it is antifreeze, it will eat your clutches for lunch.
If it is water, the steel will rust, and the glue in the gaskets will start to seperate.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 8, 2001 | 02:45 PM
dan92z28's Avatar
Update on the problem I have recently found out that there is no trans oil in the radiator. Now what do i do? Today i will drain and flush the trans along with replacing it with new fluid. Do you thik this will work?
Old Jan 8, 2001 | 02:56 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
You could always take you car to Midas and have them completely flush it. It cost about $100.00 to flush and condition your tranny oil. No, they do not remove the tranny pan, they disconnect your coolant lines from your tranny and have the car run for about 30 minutes. May want to call them and get the specifics. Hope this helps...
Old Jan 14, 2001 | 01:11 AM
812MANY's Avatar
Have you been driving through deep puddles or snow? There IS a small vent on the top of the tranny just in back of the bell housing.
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
Hello, Michael
Aug 20, 2015 03:19 PM
