flex plate?
Old Sep 23, 2008 | 06:31 PM
mark 87gta's Avatar
Car: 87 trans am gta
Engine: 355 ci
Axle/Gears: 327 for now work in progress
flex plate?
is it possible to replace a flexplate without removing the trans my thinking is to remove crossmember driveshaft all the bell bolts but the bottom 2 but replace them with like 5 inch long bolts and slide the trans back will this work
Old Sep 23, 2008 | 07:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: flex plate?
Yes, it'll work if you disconnect the cooler lines and pull the dipstick tube. You're practically removing the transmission that way anyway, just not lowering it out of the car.
codeysabatini
Nov 10, 2015 04:07 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
