700R4 in a 82 Z28?
Old Jan 12, 2001 | 03:44 PM
82-Z28's Avatar
700R4 in a 82 Z28?
Howdy all,
This is my first post here.
I have a 200C tranny in my 82 Z-28.
I want overdrive and the 700R4 looks like the
only real option.
Has anyone ever made this swap?
I know I'll need a shorter driveshaft, a different cross-member and a different shifter/cable.
What about the speedometer drive?
Is the elec plug for the TCC the same?
Can I use the kickdown cable linkage to operate the TV cable on the 700R4?
What else am I forgetting?
Thx,
John C.
P.S. Cool site!!
Old Jan 12, 2001 | 05:29 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Originally posted by 82-Z28:
Howdy all,
only real option.
Thx,
John C.
P.S. Cool site!!
1. Chevy did it for me.
2. You can use a crossmember, driveshaft (or aluminum), and shift plate from any '83-'92 F-body.
3. It's mechanical, so no problems.
4. I would think so, never seen a 200C real closely.
5. Use th TV cable from the 700 trans, should come with it.
6. Yeah, the torque converter.
There are two diiferent trans, 27 spline ('83-'late '84) and 30 spline (late '84 newer). But from what I have been told, they are equally strong for street cars. Just the 30-spline has more TC choices.
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member: SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited January 12, 2001).]
Old Jan 12, 2001 | 06:09 PM
ronterry's Avatar
Car: '94 Corvette
Don't forget about the torque arm bracket.
You can either use a tailshaft off a third gen 700, or get a conversion kit from B&M or hurst, which you might what to do anywise, since it comes with other stuff for the crossmember etc...
It's a bit more of a pain to do the 200c to 700, than it is to do the 200c to 350. However there's plenty of people that have done on this board. Sorry I went from 200c to 350.
Good Luck,
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Jan 12, 2001 | 09:35 PM
82camaro's Avatar
Car: 82 camaro SC
The main problem will be the crossmember. A later crossmember won't bolt in because the subframe doesn't have the provisions in the correct location. The bolt holes need to be back a few inches in the subframe. I've done this swap. I modified(cut and welded) the current crossmember to fit the 700r4. Also did the th200c to th350(much easier). I got my 700r4 from a astro van and it already had the provisions to mount the torque arm. I had to cut a few inches off the torque arm because it covers up the speedo hook-up. B and M shifter corrected the shifter problems. TCI controls the lock-up of the tcc. With 3.73's, the overdrive is much nicer on the highway. Any more questions, send me an email(on my web site).
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
[This message has been edited by 82camaro (edited January 16, 2001).]
Old Jan 15, 2001 | 02:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My donor car was an '86, so I was able to use all factory parts. Except, as 82camaro says, there are no crossmember holes in the proper place in the '82 frame (even if you have the proper crossmember). I simply elongated a drain hole at the end of the frame on each side for access, then put nuts & washers inside the frame for the back two holes.
Having all the factory pieces certainly made it easier (crossmember, driveshaft, torque arm, TV cable & carb bracket, cooler lines). I would recommend the same.
Your current speedo drive should work, by the way, as well as the TCC connector. You'll probably have to match the speedo drive gear(s) for your rear axle ratio.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Vojtush31
Oct 11, 2015 01:07 PM
L0tuS
Oct 4, 2015 08:07 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
