What are the weak points of a T-5?
Car: A Camaro
Engine: Weak
Transmission: Weaker
What causes this tranny to fail? Why does everyone swap in a T-56? How much torque can each year T-5 handle? Will a more powerful clutch, steel bearing retainer, new throwout bearing etc. make it able to handle 400+ lb. ft. of torque? Any help would be appreciated, Tony
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There really arent a lot of ways to beef up a T5. I hear the 83-87 version is rated around 285 ft/lbs and the 88-92 world class version is rated around 315 ft/lbs. Driving around town, it will last for a long time. But racing it is what breaks it. People switch to the T56 or Tremec because they are stronger and last longer.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
The T5 uses basically standard parts. My T5 is on the way out,and i am going to swap in a Tremec TKO.
1991 TA WS6 305/5 spd
Nitrous,hooker shorties,flowmaster 3" cat back,3.73's and a 160 shot of nitrous
DragStars 15x3.5 et fronts,15x10 rears with 275-50/15 BFG DR
1997 TA LT1
Draglites,15x3.5 sportsman pros
16x9 255-50/16 Comp TA's or Drag radials
Moroso CAI,no sway bar,dynomax non catback
1997 TA LT1
Car: 4
Engine: 6
Transmission: 5
Ummm...... the T-5 causes it to fail. That's the weak point.
Seriously, the case is too weak to hold the gears together; the shafts and gears are all quite small; and the design is for gas mileage not strength.
There are a few things you can do to help it out, but speaking strictly from experience you'll be replacing parts alot at that torque level. I have a 400 that puts 373 ft-lbs to the rear wheels through a T-5, and I've been through quite a few of them I can assure you.
