700r4 -- no second gear.......
Old Jan 13, 2001 | 12:48 AM
quartermileguy's Avatar
I know it's not a camaro but i have a 700r4 in a 90 K1500. It won't shift into second gear, it will shift directly to third if you bring the rpm's up and let off. But, if you manually put it in second it will rev up in first and never shift...if you let off the gas while reving first it will 'coast' (engine will idle down) and it won't shift if you step on the gas again it won't put any power to the wheels until you get back to the rpm you left off at.
When i burned up third it wouldn't skip to forth, so i don't know if i burned up the second gear clutchs or if it's a different problem.
PLEASE LET ME KNOW WHAT YOU THINK, I'M AT A LOSS!!!!
Old Jan 13, 2001 | 04:58 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Most likely you burned up your band. This is used in both 2nd and 4th gear. This is usually the main culprit when 2nd and 4th are gone.
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven.com
Old Jan 13, 2001 | 05:01 AM
forth is ok.....
sorry i didn't mention that earlier.
Old Jan 13, 2001 | 07:26 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Do you have reverse? Are you sure 4th is OK. its hard to believe that you have 4th if you don't have 2nd. Like Raven mentioned, 2nd gear shares the band w/ 4th gear, so if the band is toast, you don't have 4th either.
There is no "2nd gear clutch". The only difference between 1st gear and 2nd is the band, and it is shared by 4th gear. Are you sure its just not the TCC locking up in third?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 13, 2001 | 07:33 AM
reverse works
first works
second definately doesn't
third works
forth 99.44% sure it works....
guess it will have to wait until it warms up and i can tear it out, too much snow now and i have to plow with the truck. Figures, first time CT gets this much snow in a while and i have to limp my tranny thru plow season!!!
AGAIN, I APPRECIATE ALL YOU SUGGESTIONS, I'M TRYING TO PROVIDE AS MUCH INFO AS I CAN TO YOU, I'M LOST AND CAN'T TEAR INTO IT YET!!
Old Jan 13, 2001 | 09:54 AM
Blade's Avatar
Well mine did the exact same thing and it turns out some of the clutches were fried and the band was gone also. Time for a rebuild buddy.
Old Jan 13, 2001 | 10:02 PM
burnoutrpm's Avatar
I had my 700r-4 lose overdrive(4th) and reverse (aghhhh what a nightmare!!!! that was!) its either the cable (tv) adjustment or the thing is screwed.
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods 400 performer rpm intake (polished) and 600 edlebrock carb, comp roller cam, and way better heads. orpossibly a 383 stroker?
Old Jan 16, 2001 | 06:54 AM
Nitro Don's Avatar
Mine lost 2nd but still had 4th.A day later it all went to HELL!!
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
