700r4 lock up wiring question
Old Sep 25, 2008 | 08:11 PM
bmfIROC-Z's Avatar
I recently swapped a 94 lt1 into my 86 iroc and the 4l60e that came with the lt1 was shot so I had to reuse my 700r4. I already swapped in the reluctor and vss sensor and got tv cable hooked up and I'm having the 4l60e tuned out of the pcm, but I need to know how to wire the lock up for now because I don't have the money for a kit at the moment. My question is is there anyway to wire up a manual lock up to a toggle switch? Any help would be appreciated. Thanks in advance, Joe
Old Sep 25, 2008 | 08:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 lock up wiring question
+12v to pin A and ground to pin D of the TCC connector.
Old Sep 26, 2008 | 10:52 AM
bmfIROC-Z's Avatar
would i only lock it up when in overdrive?if not when should i lock it up so i dont hurt the trans?
Old Sep 26, 2008 | 03:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You should at the very least have it locked up while cruising in overdrive.
Old Sep 27, 2008 | 02:28 AM
bmfIROC-Z's Avatar
should i have it constantly locked up?im a little unclear on how a lock up converter works or what all has to do with the lock up converter.
Old Sep 27, 2008 | 10:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Check the sticky in the carb forum.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
