700r4 Pump Question
Old Sep 26, 2008 | 06:34 PM
mmather1's Avatar
700r4 Pump Question
Hey everyone just a quick question, i have been looking around on here and i keep saying that if the front pump casting ends with 732 that the trans is better, because of the 10 vane pump ,and other stuff.... but when i tore mine down to rebuild it , it has the 732 casting, but there is only 7 vanes in it? did they ever come like this, or has someone put this in for some odd reason? this is an 86 model and there is no aux valve body.
Old Sep 27, 2008 | 10:19 AM
Pro Built Automatics's Avatar
Re: 700r4 Pump Question
All transmissions from about mid 1984 are 10 vane. The #732 front pump is a 1987 and up. Comes with a larger drainback hole and a lip to keep the bushing from walking out. Dana
Old Sep 27, 2008 | 10:47 AM
mmather1's Avatar
Interesting, So someone has put the wrong guts in the pump and changed it to a 7 vane? If they cheaped out like that when putting it together now it makes sense why it did not last. Now is it normal for the the 732 pump to be used without an aux valve body? I read somewhere that there is a hole that needs to be pluged.
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
