Do i remove brake cylinder to put in hydraulics?
Old Jan 16, 2001 | 07:23 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
The hydraulics came in today and i spent 5 hours trying to get them in but i cant...should i remove the brake cylinder? I had to drill the hole for the master cylinder for the clutch correct..there was another hole right there and i didnt know if that was it or not!
89 Firebird (AKA "Money")
2.8 V6 w/ t5 tranny (383 tpi t56 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
Next:
Spohn Torque Arm, Lakewood Panhard bar, BMR Fabrication Sub Frame connectors...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Jan 16, 2001 | 08:13 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll probably just need to unbolt the booster from inside the car and pull it forward enough for clearance...that's what I did when I swapped to the hydraulic from the mechanical one; course I had the pedal/bracket assembly out at the time so it was easy.
Pete
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
