clutch help in 91 f-body
Old Sep 26, 2008 | 11:54 PM
fkboatman's Avatar
So all these people on here and no-one has done a clutch in a f-body or no-one cares to share any helpful tips. thanks for not helping or shareing.
Old Sep 27, 2008 | 12:43 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: clutch help in 91 f-body
Uhhh what? I dont see a question here for us to help you.
Did you first to see all the other threads about clutch installs?
Old Sep 27, 2008 | 02:08 AM
fkboatman's Avatar
well yeah i did, thanks. all about mechanical not hydraulic. just wanted to know if any one had any suggestions to share to make the job easier, like anything on motor need to be removed to get motor lower in back that may hang you up, does the whole exhaust need to be removed, any better swing arm bracket then the factory set-up, where to disconnect the hydraulics at and the best way to bleed it out when installed. do you p ull the bell housing with tranny or not. just like I said looking for some tips. thanks I already asked this kind of stuff in my previous post and no-one answered so I just asked what I did in this post.
Old Sep 30, 2008 | 02:34 AM
Kevin91Z's Avatar
Where's the original thread? I'll respond there.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
