Limited Slip or Not?
Old Sep 29, 2008 | 08:31 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Some of the time when I do burnouts I have a one wheel flamer (ussually when the tires are not warmed up) but I also have gotten both wheels to break loose and leave rubber on the ground (usually after the tires have been warmed up) I know I have 2.73 gears as I have rear drum brakes. I haven't been able to clean off my Rear Axle ID number enough yet. All I can see so far is 2H, which tells me nothing. I know that there was an option for 2.73 with limited slip,(says so in my GM Shop Manual for my 1986 Camaro). I am wondering if I have a limited slip that is not working right? Because I thought you couldn't brake both tires loose on an open differencial.
1986 Iroc-Z
Automatic
Rear Drum Brakes
Old Sep 29, 2008 | 08:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Limited Slip or Not?
An open differential will sometimes spin both tires. The only way to know for sure what you have is to open the cover and look.
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Only real way to tell is to open the rear up and look. My 91 RS had a 2.73 open/drum rear when I got it, and I could sometimes get both wheels going.
Old Sep 30, 2008 | 06:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You can open the rear up or check for RPO code G80.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
