Clutch pedal question? Need Help!!
Old Jan 15, 2001 | 07:09 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Ok I am going to install the pedal assembly. I was looking at the wires that go from my auto shifter under the dash they are Yellow and purple,if I remember correctly. The thick wires on my pedals are I think green and orange. My car is at my parnets house that is why I am not sure. Anyway,even though they are different color wires I believe they are for the same thing. Clutch safety switch, or the auto saftey switch. The connecters are diff too. My car is a 1984 and the pedals are 1992, but this shouldnt matter. Can I just splice the wires? They both have the letters A B on them and say ped #3 so I believe they are the same wires just diff color and connecter. Does anyone know. Thank you very much Kevin
Old Jan 16, 2001 | 11:56 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Anyone???????????
Old Jan 16, 2001 | 05:07 PM
Birmass's Avatar
Yes, the purple and yellow wires by the shifter are for enabling the starter. If you had an automatic there is also a purple and yellow wire connector by the pedals, but it is not connected. They are the same. Either can be hooked up to enable the starter while leaving the others disconnected. I'm not sure about the orange and blue ones though. I don't think they are for the starter.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 16, 2001 | 05:55 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Ok so if I hook up those wires YELLOW AND PURPLE to my clutch safety switch it should work then? Thanks Kevin
Old Jan 17, 2001 | 10:31 AM
Birmass's Avatar
Yes, definitely.
Old Jan 18, 2001 | 03:22 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
So that's what that connector with wires that I keep stepping on are for.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
