Z/ T takeoff vs. Auburn unit
Old Jan 17, 2001 | 11:35 PM
CamaroZ_85's Avatar
which is better? I know the Z/T is liek $100 compared to $3-400 auburn. is the auburn worth the extra cash???? also, is either of the 2 easier to set up?? I's like to build up my rear this spring...any suggestions appreciated
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Jan 17, 2001 | 11:48 PM
89BlwnRs's Avatar
Wanna see how it goes? Read my article on the Trans/Drivetrain board. Just like for 89BlwnRs as the poster and check it out. I had 26 splines like you should have, and I installed a ZT take-off.
I recently installed a ZT take-off from SLP in my 89. Both the ZT and the Auburn are set up the same way, except the ZT is only for 28 spline axles. If your car is an 85, you have 26 spline axles. You can always swap 28 spline axles in, they're a little stronger due to their spline count, and they're not necked down like the factory GM ones are when you approach the C-clip.
Hope this helps,
Jason
Old Jan 18, 2001 | 06:15 PM
82camaro's Avatar
Car: 82 camaro SC
powertrax.
new bearings might be a good idea, and different gears if you want them.
If your current gears are acceptable, the powertrax installs without removing the gears/carrier. All that comes out is the spider gears.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
