Everyone help me find the cheapest way to get a better (lower geared) rear end....
Old Jan 16, 2001 | 02:05 AM
Dan87IROC-Z's Avatar
I currently have the old Borg Warner 7.75" 9 bolt in my IROC with the crappy 2.77s. With the new cam I am installing, I will want deeper gears ASAP and ACAP (as cheap as possible). I don't need anything radical like 4.10s or anything. I'd be happy with 3.2Xs, 3.4Xs or even 3.7Xs. I don't care, 9 bolt or 10 bolt, discs or drums. But I will have to have a speed shop swap rears or gears, so thats gonna cost some $$. I just need to find the cheapest way to do this, all suggestions are welcome!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 16, 2001 | 06:59 AM
Nitro Don's Avatar
swap a new rear in from the bone yard!
Thats cheap!!
Nitro Don
Old Jan 16, 2001 | 09:00 AM
Desert86Roc's Avatar
Ditto....I found a wrecked 90 IROC, and swapped the rear to my 82 firebird, and then into my current IROC. POSI... 3.23 and the nice aluminum calipers...and it bolted right in with no mods. Those of you swapping from drum to disc rears may have to fab an adapter for the brake lines (my 82 had large tube drum lines, and the disc rear had small tube)....
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Old Jan 16, 2001 | 09:12 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
look in 1985-90 camaros with 6 cylinders,most of them came with 3.42s.i got one out of an 88.firebirds may be the same
Old Jan 16, 2001 | 10:55 PM
Thanks guys, anyone know of any salvage yards in northern colorado? Also, what will a complete rear end cost me?
L98 TPI 350 (5.7L)
Old Jan 17, 2001 | 09:33 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I was looking for a complete rear myself. I found that a one legger will go for $150-200 and the posi axles will go for $300-450!!
I found a 3:73 rear and am putting the SLP take-off posi unit in it. If you go my route, make sure that it has 28 splines!
  • 89 Formula 305 WS6
    SFC's,
    LCA's,
    Air foil
    Flowmaster cat back
    Tranny Cooler
  • 90 Eagle Talon 2.0
    (winter beater)
Old Jan 17, 2001 | 01:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yup, V6 Firebirds from those years (altho I thought it was from 85-88) also have 3.42/open/drum axles.
I scored a 3.73/posi/disc axle from an '84 Trans Am for $150. That's a rare axle, offered between '83 and '85. If you find an '84 t/a in a junkyard with engine code "G", and a manual transmission, then chances are you've found my axle!
Of course, in the junkyard, pull the cover & check all the ring/pinion teeth out before you buy. It's also a great time to double-check the ratio.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 17, 2001 | 02:07 PM
Cowboy's Avatar
I've got a 9 bolt posi from my '87 IROC with 3.27s in it. I'd sell it for $250 but shipping will kill ya. It would have to go truck freight. It's got discs on it also.
Old Jan 18, 2001 | 11:13 PM
Anyone else have any ideas or anything to say?
L98 TPI 350 (5.7L)
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
jklein337
Sep 19, 2018 06:23 PM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
