Hatch release on t56 swap
Old Sep 29, 2008 | 06:27 PM
EROC88's Avatar
Car: 88 IROC-Z
Engine: 355 T.P.I.
Transmission: t56
Axle/Gears: gm 10 bolt, 3.90 gears
how do you wire the switch for the hatch release? it doesn't work without the switch on the automatic shifter. what do i do?
Old Sep 29, 2008 | 08:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Hatch release on t56 swap
I'd say cut out the switch, splice the wires together. Then it will work all the time. Or one could wire it into the parking brake if you wanted a functional switch.
Old Oct 1, 2008 | 04:31 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
take the brown(I think, been a while) wire from the hatch switch. Wire it in a three way connection with the parking brake switch and the hatch release will only work when the park brake is engaged jsut as it would have been from the factory.
AussiePr0nCar
Mar 6, 2020 04:04 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
19irocz85
Aug 26, 2015 07:54 PM
neekolzun
Aug 24, 2015 04:59 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
