91 RS Automatic Mount
i think i have a little demon or something that hangs out under my tranny cus the mounts dont seem to hold up 2 anything. I gotten damn good at changing the mounts, this time it will be polyurethane. But my question is about the crossmember. I change it without taking it off. Takes a lil wiggle and some elbow grease but it goes in. I do this cus i was told that its not good to take off the cross member because it get out of alignment. Is this true or am i jus wasting all that effort and could get it done alot easier?
One more thing what kind of tranny is in my car? its a 91 RS 3.1 automatic
91 3.1 RS.
T-Tops
12" tube in the trunk
16" ROH Rims (Need Center Caps) ROH Rims
Firehawks all Around
[This message has been edited by XxMoLexX (edited January 21, 2001).]
91 3.1 RS.
T-Tops
Hey I broke 3 rubber mounts with my manual T-5. 2 with the v-6 t-5 combo and 1 with the v-8 muncie combo. I finally went to a poly mount and with a richmond 6-speed once i broke the muncie. I have had no probs since. I am not sure but I have never heard of having alignment problems if you take out the cross member. I always taken it out myself. I put a jack under the tranny and un bolt it. Takes about a half hour, taking most of the time jacking the car up and putting on jack stands and back down. Someone correct me if I'm wrong but you shouldn't have any alignment probs when taking out the crossmember. To make absoult sure, when reinstalling look at the round marks scraped into the crossmember by the bolts, and make sure the the bolt match excatly into those marks when it goes back in. That way you will know it is back into the exact same position.
Car: 4
Engine: 6
Transmission: 5
You can do it either way, whichever is easier for you. You won't hurt anything taking the x-member off. I usually do.
ICON Motorsports
ICON Motorsports
Ok thanks for the help guys... i just wanted to know before i went and screwed something up
91 3.1 RS.
T-Tops
91 3.1 RS.
T-Tops
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
