Setting TV Cable
Old Jan 24, 2001 | 12:52 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Setting TV Cable
What is the ideal tension setting for the Trottle Valve cable in a 700R4 with an L98 TPI?? With the shifter in "D" the car shifts at 4900 RPM's during WOT. Is this what the car should shift at?
1988 GTA 5.7L Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Throttle Body Bypass Hose, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, LPE Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Jan 24, 2001 | 01:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The ideal tension setting is how the cable adjusts itself. You might be able to get a click or two backwards (to increase the line pressure), but if you go too far back, the cable readjusts itself as soon as you push the gas pedal to the floorboard.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 24, 2001 | 06:03 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
I'm at the other end of the spectrum. My iroc shifts at 5750 - 6000 rpm. The car originally had a L98 but it was changed to a old 305. I don't know why, but my shifts really high, and I just adjusted the TV cable.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
