86 700-R4 guts into a 89 700-R4 tranny?
Old Jan 24, 2001 | 08:17 PM
EO273KiD's Avatar
Ok, I have a broken 89 700-R4 with a shattered round gear cage thing (the round thing that holds the planetary gears in) and now my 86 700-R4 is begining to not shift until I hit 6,500 RPM. I really need to get one working tranny out of the two and I was wondering if the guts on the inside of the trannies are the same? I plan on rebuilding the 89 over rebuilding the 86 as I heard the 89 has a better design. Any input? Thanx?
Owner of a 1989 IROC Camaro, a.k.a. "The Babe Magnet". Painted a cheap metallic blue that chips off all too easily and covers over the IROC decals on the doors, also has non-leaking T-tops, ps, pw, power rear hatch, working A/C. Mods: SLP intake runners, gutted MAF sensor, adjustable fuel pressure regulator, modified air spoil, 3.2? posi rear end.
Broken stuff: rear spoiler brake light, driver side lock, power antenna, tilt steering, rear end bushings, cracked passanger side ground effect, washer fluid tab, leaking exhaust and a rotted through muffler that sparks when the car bottoms out while driving like any 17 year old does.
Old Jan 24, 2001 | 08:54 PM
Nordbert's Avatar
A lot of the '86 and '89 700-r4 parts will
interchange. I recommend rebuilding the '89
because it has a few more upgrades. Most
transmission shops are willing to inspect
suspect parts and give you good advice if
you are planning to rebuild it yourself.
Old Jan 24, 2001 | 10:19 PM
MrJ's Avatar
MrJ
I wouldn't do it... the 86 700R4 ain't that great. The tranny become much better in 87, and was improved every year until 1993, when the 4L60E came out.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
