Rear End Swap
Rear End Swap
Need some further info. I currently purchased the rear end w/ disc brakes that was removed from a wrecked 2002 camaro RS. Im going to install it into my 89 iroc w/ drums. The 00 rear end needs 1 new brake caliper. Can I replace that caliper w/ one from an 89 camaro that does not have SBS braking since my 89 does not have SBS? Also is this a direct swap or will I need to replace the master cylinder or anything else? Im new at this and I'm trying to learn. Please help.
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Rear End Swap
i believe youll have to change the master cylinder but im not positive. as for the calipers i think they might be different
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Rear End Swap
Calipers are totally different. Do a search, all the info has been cover a million times on how to do this. You will need a proportioning valve for a rear disc car, I bought a 1LE vavle when I did my swap. The hard brake lines will have to be modified. And you'll lose the ebrake unless you fab something up. It's been done, just start searching and reading.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
