Rear Axle Noise
Old Oct 7, 2008 | 04:06 PM
firebirdman's Avatar
Car: 89 Firebird Formula
Engine: 305 tbi
Axle/Gears: 10 bolt 3.42
Rear Axle Noise
I have an 89 firebird. 305 tbi it has a 10 bolt axle with 2.73 gears. I Just replaced the driverside axle shaft and put in a new bearing. When i test drove it it had a distinct howl. I talked to a mechanic and he said it was probly a different bering going out. Recently i can hear a loud clanking noise. I quit driving it and am trying to figure out if it is just the bearing or something else. Any info will be helpfull.
Old Oct 7, 2008 | 04:44 PM
big gear head's Avatar
Re: Rear Axle Noise
I guess this noise is new and wasn't there before the axle was replaced? This is probably a stupid question, but you did put 2 quarts of gear oil in after the axle was installed, right? Did you put some oil in the axle bearing before you put the axle in?
Old Oct 7, 2008 | 04:56 PM
Engine: 305 tbi
Re: Rear Axle Noise
The axle shaft was bent because the previose owner hit a telephone pole. So i replaced the axle shaft. Yes i did put 2 quarts of gear oil in after i replaced it. and yes i did put some oil in the axle bearing before i put it in.
Old Oct 8, 2008 | 08:06 AM
Re: Rear Axle Noise
Do you think the axle tube might be bent?
Old Oct 8, 2008 | 01:31 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Rear Axle Noise
Did you put posi additive if it is a posi rear? If the sound is more of a winding noise that could be your problem. Is there a particular side you can hear the noise from?
Old Oct 8, 2008 | 07:30 PM
Engine: 305 tbi
Re: Rear Axle Noise
I dont believe the tube is bent. I guess i havent taken a close look at it. It isnt a posi differential so i didnt put any additive in. The noise seems to be coming from the center. I guess i could check it out more. Its not a winding noise, it sounds like metal is taping together. It doesnt sound good.
Old Oct 9, 2008 | 01:08 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Rear Axle Noise
put the rear end in the air and open up the cover and turn the wheels and see if u can locate the noise.
Old Oct 9, 2008 | 06:48 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: Rear Axle Noise
did you change the race too? How are your u-joints and pinion bearing? The u-joints could contribute to your clunk as well.
Old Oct 10, 2008 | 12:55 AM
Re: Rear Axle Noise
yes bad u joints, would contribute to a clanking noise, but only if the noise is heard when going from Park to drive, or Park to reverse, otherwise the bad u joint would vibrate when driving, and play would be even more noticed when the driveshaft is turned by hand. a u joint could be the problem, but the same sound can be caused by a bad torque arm bushing, too much backlash in the ring and pinion gear. one way to tell if its a bearing on its way out is if it gets louder the faster you drive. you can knock off another couple of possibilities if u figure out whether it makes noise when your coasting(foot off the throttle) or when you accelerate(torque sensitive) and that will help you narrow down between the front pinion bearing or the rear pinion bearing, but even if one was worn out, itd be good practice to just change both while the differential is being serviced, and while your at it you might aswell swap in some steeper gears, and then while your at it swap out that other axle. but also this all has to do with your budget, if your just trying to get this thing to run, do the diagnosis, but if u want this car to be mean as hell, swap out the gears(if it turns out the problem is a pinion bearing)
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
E Rod
Aug 28, 2015 05:17 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
