dumb question, don't laugh
Old Jan 29, 2001 | 06:44 PM
MrF-body's Avatar
i have heard that GM sells a 6-speed transmission that is a direct replacemant for the t-5 is this true? any idea of cost?
Old Jan 29, 2001 | 06:55 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
havent heard of it...T56 is the closest thing I'd guess, probably get one used for around 1200?????? Is NOT a direct bolt in by the way.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Jan 29, 2001 | 08:36 PM
AustinT's Avatar
You are right there is a aftermarket version GM aftermarket replacement T-56 six speed is designed to replace the T5 five speed in the 82-92 Camaros and Firebirds. This transmission can be used for many other applications with small modifications.
Gear-ratio spread: 2.97:1, 1.94:1, 1.35:1, 1.00:1, 0.84:1, 0.62:1 forward, and 3.28:1 reverse. The tranny uses a adapter plate to bolt up to the t5 bellhousing. It has a longer input shaft to make up for the difference of the plate. To use the aftermarket t56 you have to shorten the driveshaft and The long stabalizer arm 2 inches. THe tranny is rated at 400 lbs of torque instead of 450 like the production t56 because the aftermarket tranny has the lower gears. The shifter will come out in the right place, You wont have to cut a thing. The tranny has a different tailshaft with a mechanical speedo to make it even easier. The only drawback is 2300. I am also in need of a t56 but cant decide wich way to go Aftermarket t56, production t56, or find a way to use a viper t56. Here is a good place to get the aftermarket t56 should you decide to go with it http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
Old Jan 29, 2001 | 08:47 PM
MrF-body's Avatar
YOU ARE THE MAN, AUSTIN!!!!! thank you for the good information
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
