flexplate replacement
Old Jan 28, 2001 | 11:01 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I think I have some teeth missing on the ring gear on my flexplate becuase sometimes when I go to start it the starter will just make a loud grinding noise and I have to move the car abit to get it to work.
any way what I wanted to know was is there a light weight FLEXPLATE on the market.
I know there are heavyer ones for improved launches but i wanted to know if anyone knows of lighter ones for better acceleration??
thanx
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
http://www.geocities.com/transam617
Old Jan 29, 2001 | 01:39 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
btt
Old Jan 29, 2001 | 02:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you did have teeth missing on the flexplate, I don't think moving the car a bit would help. It might be a problem with your starter.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 385 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Because you can always sleep in your car, but you can't drive your house.
Old Jan 29, 2001 | 04:51 PM
merf23's Avatar
They are pretty light to begin with. Most of the rotating weight is from the torque converter and the internal tranny parts.
I have a flexplate that ill sell for $20 plus shipping if you want. Its a OEM one from an 87 motor i bought in excellent condition.
Old Jan 29, 2001 | 10:09 PM
ronterry's Avatar
Car: '94 Corvette
I can't remember hearing of a light wieght one, but the after market flexplate are more for durability. Never heard that they give you a better launch, but certainly they can handle those forces without breaking.
The after market flexplates like the TCI (the one I have) are much thicker then the OEM. I've seen quite a few aftermarket plates very in thickness as a saleing point.
Most of the plates I've seen don't really have missing teeth, but more of hafe moon cut out of teeth from ware.
Good Luck,
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Sep 24, 2015 09:12 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
