th350 driveshaft length
i am putting a th350 in my 82 camaro it was prevesiously a 700r4 fromt he factory and i am curious what driveshaft i need i have a 1le from an 88 gta but was told it was short. any help on the matter would be appreciated
Johnathon Lattanzi
Johnathon Lattanzi
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If it's a 9" long tail shaft TH350 then the 700R4 driveshaft is a direct fit. If it's the short 6" tailshaft then you need to lengthen the shaft or find one from an 82-83 with the 200c tranny.
Hmmm. I just re-read the first post. 82's didn't come with a 700R4 so you probably have the 200c tranny.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited January 31, 2001).]
Best 60 foot: 1.662
wigmobile
Feb 26, 2025 02:56 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
350, 95, camaro, drive, driveshaft, driveshaftlength, driveshaftt, length, long, powerglide, reverse, shaft, stuck, tail, th350
