7.5 Rearend Question
Old Feb 1, 2001 | 10:45 PM
Basett Racing's Avatar
I am about to change the gear ratio in my 82 Z28. I already have a 7.5 w/ 4.11's that I have raced for a few seasons with no trouble, but I am changing engines and I'm going w/ 4.56's. I am going to leave the rearend alone that I have in the car now, in case I break one during the season, I 'll still be able to compete for points. I have 2 rearends, an '89 rearend with factory 2.73 gears, and the other is a '90 rearend with 3.42 gears. I know that the the 2-series carriers and the 3-series carriers are diiferent, but which one is stronger?? Since I haven't bought anything yet, I want to build the stronger of the two. BTW, I'll be using an Auburn minispool like my the rearend I have now. Thanx
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
Old Feb 2, 2001 | 04:25 AM
ede's Avatar
ede
as far as i know the only differance is the thickness of the flange the ring gear sits on. if both were 28 spline axles i don't think i'd worry about it too much either way.
ICON Motorsports
1st & 3rd
Old Feb 2, 2001 | 10:08 AM
89ProchargedROC's Avatar
the thickness of the flange is the same, it is just the height of the carrier that is different. that is all.
Old Feb 2, 2001 | 03:58 PM
Neither of the rearends are taken apart, just the rear cover has been removed to check the gears. Shouldn't all '89 and '90 rearends be 28 spline?? The one that is in my car now is a '84 and its a 26 spline.
So when you say the height of the carrier is different, I'm assuming you mean the higher (numerically) rearend has a taller carrier, therefore meaning more material, right??
Bassett Racing
Old Feb 2, 2001 | 05:05 PM
ede's Avatar
ede
yeah that's what i meant to say, i don't know how i got it turned around like i did. or maybe i was just guessing? thanks for setting me straight.
ICON Motorsports
1st & 3rd
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
toronto formula
Nov 10, 2015 06:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
