gear question
Old Feb 2, 2001 | 09:50 PM
Z28Maniac's Avatar
gear question
Can the gear ratio in a GM 10 bolt be changed by replacing the ring and pinion or is a whole new rear end required? I wanna put 3.73s in my '91 RS.
Old Feb 2, 2001 | 10:09 PM
AustinT's Avatar
you just have to swap the ring and pinion. get one the the carrier your rearend has
What gears do you have now?
Old Feb 3, 2001 | 02:18 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your RS probably has an open rear end now, right? Go to www.slponline.com and get their take off torsen posi for $100. Then get your 3.73 gears (3 series carrier with that posi), along with the correct speedo gears for your trans, so your speedo will read correctly. Then pay a good shop to install it all for you, as gear installs are very tricky and require special equipment. Good luck!
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 3, 2001 | 09:28 PM
Z28Maniac's Avatar
Thanks! I'll check into that. I have 2.73s in the RS and they suck! My '85 Z28 has 3.23s (3.27s?) and it accelerates soooooo much quicker than the RS. I think the TPI induction has a little to do with that, but I know my RS could move faster with steeper gears!
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
