gearing question
Old Oct 12, 2008 | 07:35 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
gearing question
this is going to sound stupid but here goes i have no idea what rear gear ratio i have and i would really like to know for future gearing puposes i dont think it is the one that came it my car because the guy i bought it from kinda peiced the car together what i do know is the trans is a v8 t5 and at 60 in 5th im only slighly off idle, if it helps its a non posi
thanks for any help
Old Oct 12, 2008 | 07:48 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: gearing question
Have one rear tire on the ground, the other in the air, and the transmission in neutral. Spin the tire that's in the air until the driveshaft makes one rotation. Half the number of tire rotations is the gear ratio, so expect to turn the tire about 7 rotations for one driveshaft rotation.
Old Oct 13, 2008 | 10:47 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
the best way to find out what ratio you have is to remove the cover and count the teeth on the gears. Then divide the ring gear teeth by the pinion teeth = gear ratio. This would also provide the opportunity to change the gear oil(who knows how long it's been there). hope this helps
Old Oct 13, 2008 | 10:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Numbers are stamped on the ring and pinion:
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Old Oct 13, 2008 | 09:04 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
thanks ill just pull the cover cause i should probably change the oil anyway
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
