Will This T5 World Class withstand my Big Block 454 1969 Nova
Old Oct 9, 2008 | 07:19 PM
TeckJohn's Avatar
Will a 1352-213 GM 1992 1/2 MY-F Work with big block?
1352-213 GM 1992 1/2 MY-F Car WC U2.762.951.941.341.000.63
here is a link to my trans http://alacable.com/borg/ will it be durable enough
I need to know if this is a World Class trans and is for a V8? I have a 1969 Nova with a new 454 30 over
Aluminum intake. New holley performance carb around 400 to 450 horse. Right now I have a Borg T10
Aluminum 4 speed with the fine clutch spline. I do not want to put a trans in here that is going to be weak.
I'm not a racer! But I will drive this car to it's potential occasionally . Just need to know which trans to use.
I really want the T5 as is it a top loader and no shift linkage and it's a five speed.
Old Oct 9, 2008 | 07:25 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: Will This T5 World Class withstand my Big Block 454 1969 Nova
A T5 won't stand up to a good 305, much less a rat motor. If you want an internal rail shifted trans, go with a TKO or a T56.
Old Oct 9, 2008 | 10:41 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
A quick look at the output shaft will tell you if it's for a V8. It should have 26 splines, anything less it's not for a V8. The T5 and W/C T5 are fine transmissions but not anywhere near strong enough for your application.
https://www.thirdgen.org/forums/tran...ything-we.html
Old Oct 10, 2008 | 12:58 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
no way. the T-5 is a good transmission but no way near the level that an engine that big is in. is this gonna be a street car, or a strip car or both?
Old Oct 10, 2008 | 07:20 AM
TeckJohn's Avatar
street car ... it belonged to a friend who passed away and i cant chance wrecking it...
Old Oct 10, 2008 | 03:03 PM
so your pretty set on a manual transmission then? id see if u can get an old camaro 3 speed muncie
Old Oct 10, 2008 | 03:31 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
um u mean muncie 4 speed?
Old Oct 10, 2008 | 04:03 PM
yeah, my bad im still asleep
Old Oct 10, 2008 | 04:23 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
lol i figuered somethin like that....... but hey man if your goin big with a big block y stop there go big get a T56 of a TKO600....
Old Oct 10, 2008 | 04:24 PM
TeckJohn's Avatar
Ive got a Borg T10 aluminum housing fine spline 4 speed and a turbo 400 and a turbo 350 that was in the car with a small block and the 350 and the auto trans that were in the car are souped to the max.... stall converter all the internal good parts and ther motor has $2500 worth of heads on it..... My friends dream was to have a big block .. I dont know what kind of trans he wanted
Old Oct 13, 2008 | 07:32 PM
bluechev's Avatar
my vote is no it wont. too much torque!
Old Oct 13, 2008 | 09:07 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
best case senario: absolutley not
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
jtwoods4
Sep 3, 2015 05:39 PM
