need help on conversion from auto to manual tranny
Old Feb 3, 2001 | 11:51 PM
vortech305's Avatar
I have a 92' camaro whcih had the 3.1 auto with 3:23 gears now next month i plan on putting my worked 305 into the camaro with an 85 z28 T-5 tranny w/ bellhousing I bought a hydralic resavoir from a 92 camaro RS with a 3.1 and slave cylinder from an 88' camaro will these parts work with my worked 88 305 motor. And lastly do i need to change the driveshaft and crossmember on the car. is so can u state which type i need tjha
Old Feb 3, 2001 | 11:58 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
the parts you bought will work fine. And you can use your stock driveshaft. The only difference will be the torque arm mount. I believe there is a tech article that illustrates the differences.
I did this swap, and used parts from a V6 donor car, other than the tranny, bell housing and clutch.
Proud owner of the slowest L98 in the North East
1987 IROC 5.7 - 16.43 @ 82 the project
1986 S10 4x4 w/93 Vortec 4.3 - the nitemare
1988 Formula WS6 - the Cow
[This message has been edited by Jay (edited February 04, 2001).]
Old Feb 4, 2001 | 04:38 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I don't think that the bellhousing for a V6 will mount up to a V8. I could be wrong though. There was another thread that said that.
I that what you meant by 3.1? I didn't know that the RS came with anything other than a 305,(5.0).
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
[This message has been edited by stingerssx (edited February 04, 2001).]
Old Feb 4, 2001 | 10:35 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
You are right, the V6 bell housing will not bolt up to a V8, but according to the orginal question, he bought a T5 and bell housing from a 1985 Z28, or at least that's what it looks like to me.
the 2.8/3.1 V6 came standard in the RS from 89-92, the 5.0 was the optional engine.
Old Feb 4, 2001 | 06:20 PM
vortech305's Avatar
sorry i bout the t-5 from a 85' z28 which included bellhousing and fork. sorry to include i have all necessary parts such as a torque arm from donnar car as well. JUst one more question I thought 85 z28 came with throttle bodie injection and tuned port injection now if my memory serves me correct i thought only throttle bodie injections came with t-5's and tuned ports used auto's so lets say the t-5 i bought was from a throttle bodie injection will the bellhousing fit the 88 tpi.
Old Feb 4, 2001 | 11:12 PM
Fastcamaro87's Avatar
The 1985 IROC-Z models that had the 305 TPI engine could only get the 4 speed automatic transmission, the manual transmission could only be had with the 190 H.O. carburated engine.
"IROC-Z.com"
However the bellhousing will fit your 88 motor
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Feb 5, 2001 | 10:35 AM
vortech305's Avatar
thank u
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
