4L80E in a third gen camaro?
I am building a Procharged and N2O injected 335. I am going to be producing 900-1000 hp. In trying to find a transmission, I was directed towards either a TH400 or 4L80E, because the highest rated 700R4 I could find was only to 800hp. I am going with the 4L80E because I will be using a gear vendor under/overdrive with it to obtain a .59 overdrive ratio for top speed runs over 200 mph. Has anyone installed a 4L80E in a third gen camaro? What problems are there, if any? I know it requires modification to the trans tunnel.
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
removed air pump, converter, straight pipe no muffler
0-60 5.5 sec
1/4 mile at 102mph
top speed 160mph (racing a mustang)
est 285hp
fiberglass hood
$2000 Alpine stereo hit 135 in spl comp.
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
0-60 5.5 sec
1/4 mile at 102mph
est 285hp
fiberglass hood
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My truck came from the factory with a 4L80E. In stock trim it can easily handle 500 hp or more. About 80% of the internal parts are TH400 but that's where it stops. Externally it's a bigger and heavier tranny. You might be better off cutting the entire tunnel out, install the tranny, then fabricate a new tunnel. I don't have dimensions available but it would be a complete fabrication swap.
Don't forget that the 4L80E is an entirely computer controlled tranny. A seperate computer is required for it to work. Computer kits are available to install the tranny into any vehicle but squeezing it into any vehicle is up to you.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
DONT DO IT!! i work at a tranny shop and you should listen. the 4L80E is a monster and can withstand a lot, but there really isn't an aftermarket yet for the trannies and a STOCK REBUILD at my local shops is anywhere from $1200-$1500, and that is stock. just put the same money into a bad a s s 700R4 and you will be fine. i have numerous friends who run my shops 700s in 10 second cars and they are still fine
Well my car will probably be running sub-10 sec times and the strongest 700R4 I could find was up to 800hp. I will be running 18 psi of boost with N2O. If you have a 700R4 that will stand behind that much torque, I'll be glad to look into it. The 4L80E I am looking at now is from Art Carr, and I can get it with a 2.75 first gear.
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
0-60 5.5 sec
1/4 mile at 102mph
est 285hp
fiberglass hood
1986 Iroc Z 305
3.23 posi-rear
ported mass-air
custom ram-air
0-60 5.5 sec
1/4 mile at 102mph
est 285hp
fiberglass hood
Car: 1990 iroc
Engine: 350 tpi
most trannies I have seen are rated in torque and not hp. It depends alot on your traction. you could have 1500 hp and if you are running 275-315 bfgs you aren't going to get enough tracion to break your tranny. you need to elaborate on your setup a bit. if you are not running slicks or a tranny brake you probably would not have a problem. I have yet to see many cars run 9 seconds in street trim so if you are serious about that et and not talking out your *** then you will need something like this. but if you are that serious about drag racing you would just go with a turbo 400 or a glide.
I'llrocya
Feb 2, 2016 11:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
