Cost of speedo gears for gear swap?
Old Feb 6, 2001 | 01:18 AM
Dan87IROC-Z's Avatar
I will be changing my rear end gearing from 2.77 to 3.42 here soon and was wondering what I should expect to pay for a speedo gear cable so my speedo isn't off.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 6, 2001 | 01:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The cable is the same, you're changing the speedo gears in the tailshaft of your 700R4 trans. I think they're less than $20 each from GM. You need a 15 tooth and a 41 tooth for 3.42 gears in a 700R4, *I think*
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited February 06, 2001).]
Old Feb 7, 2001 | 06:20 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I concur. Those are the gears listed in the GM parts manual for that combination of tranny, rear gears, and tires (assuming you have 245/50R16 tires). I also bought either the 40-tooth or 42-tooth gear for my shorter (245/45R16) road-race tires since it's only an easy 10-minute job to swap that gear out. The other gear is quite a bit more difficult, which is why I had my shop do it when they rebuilt the rear end.
Greg Westphal
'87 IROC 305TPI/A4
junkcltr
Aug 2, 2019 11:12 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
