Which tranny and rearend to buy?
I have intentions of putting a 383 in my 89RS. I'm hoping for between 450 to 550 hp. What would be a good manual tranny and rearend combo would work best. Also any rearends that are advised what could I pull it from. My intentions are to have a fast 1/4 mile gas guzzler with no regards to top end, however still be able to drive it daily if I choose to. Thanks in advance for any advice.
I would recomend an aftermarket rear from a company like curie that will give you anything you want(gears, posi, disc brakes, etc.) in a 9 inch that will directly bolt up to your car no cutting or welding neccessary.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
I would also recommend going with Currie. Since you live in Oceanside, they are probably an hour away from you at most. This would be best for a no-hassle install, even if you plan on doing it yourself.
I have been to the yards in Oceanside and San Diego. 9 inches are not easy to come by, and when you do find one, these guys know what to ask for them.
Currie Enterprises
1989 IROC-Z 5.7L
Currie Enterprises
1989 IROC-Z 5.7L
UltRoadWarrior9
Apr 28, 2020 10:39 PM
