Driver controlled shifts??
I was looking at a trans go kit for a 700R4 and it said gives driver full control over shifts...won't shift till you move the shifter. I am guessing this only applies when you are shifting yourself like putting it in 1st and then shifting to 2nd etc...but what about if its in D or OD, does it shift normally, just firmer??
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
90 IROC 5.7l (L98)
LIKE A ROC
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
When installed as a stage 3 kit, the TransGo kit I'm familiar with converts the transmission to full manual control. As a stage 2 kit, the transmission upshifts normally in OD but may be kept in a lower gear at any RPM by moving the selector to a lower position.
Car: 2002 SOM z28
Is it the same thing as the B&M megashifter? I can drop it into 1st and it will only go as high as first... but if I drop it into 3rd, then it will go through 1st-3rd and back down (3rd-1st) when I slow down. (I know the megashifter is a shifter and the TransGo kit installs into the tranny... but is that what he is asking too sort of?)
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Engine: 383 Carb
Transmission: 4L60
Not really, the megashifter (and all aftermarket shifters for that matter) work essentially the same as the factory shifter. A stock 700R4 supposedly will actually upshift somewhere around or above 6000 RPM regardless of the selector position. The TransGo kit will prevent this from happening.
dhonda200
Aug 11, 2015 11:50 PM
