what exactly does a kickdown switch do?
Old Feb 5, 2001 | 08:44 PM
nichoulas83Z454's Avatar
im about to swap a 454 and a th400 in my 83z and i keep hearing about a kickdown switch, and im stupid when it comes to transmissions...
Old Feb 5, 2001 | 10:48 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
the kickdown switch downshifts the tranny when you get on the gas hard. passing gear. i don't know how it knows when you are going too fast for a downshift, though.
Old Feb 5, 2001 | 11:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It supplies power to the kickdown solenoid. It has nothing to do with how fast you're going, only how far the gas pedal is pushed.
Go to the junkyard and take a look at the gas pedal bracket in the interior of some full-size GM cars from the late 60s that have Turbo 400s. That would be any Chevy, Buick, Pontiac, Olds, or Cadillac with an engine of 400 CID or larger. A picture is worth 1000 words. You'll understand it when you see it, trust me this time.
ICON Motorsports
Old Feb 8, 2001 | 11:33 AM
82z's Avatar
82z
You don't need one in a hydraulicly controlled tranny.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 8, 2001 | 11:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Gotta have one with a 400, otherwise no hard kickdown. 350s use a cable, 400s use a solenoid.
ICON Motorsports
Old Feb 9, 2001 | 05:12 PM
im still kinda in the dark about the kickdown switch... i now understand what it does... but im not sure how to hook it up...
the th400 i bought has what looks like a solenoid attached to the shifter bracket, and its got 4 wires hooked to it... what do i hook these up with, and should i get the b&m kickdown switch...
im going to the mall tommorrow to see if books-a-million has any good th400 books... anyone have any good suggestions?
Old Feb 9, 2001 | 06:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Go to the junkyard and look at some old sleds from the 60s. All will instantly become clear. One look is worth 1000 posts.
ICON Motorsports
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
