Is a disc rearend weaker than a drum?
Old Feb 10, 2001 | 08:19 PM
86IROC305's Avatar
I found a 84 HO z28 with a disc brake rear and posi(g80) with 3.73's(gt4) and I was wondering if the interals were the same as the drum rear on my 86(Are they swapable?). This the exact setup I was looking for my IROC, but if it's a weaker rear, then I'll have to think twice. BTW what would I need off the donor car to complete my swap, so the brakes work properly (ie: master cylinder, etc), Thanks
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams H268 218@.050 454/454
Old Feb 10, 2001 | 08:20 PM
ede's Avatar
ede
insides are all the same
ICON Motorsports
1st & 3rd
Old Feb 10, 2001 | 08:29 PM
86IROC305's Avatar
What would I need off the donor car for proper braking proportions?
Old Feb 10, 2001 | 08:59 PM
82z's Avatar
82z
All third gen rears are equally weak. You will need the proportioning valve off the donor car.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 11, 2001 | 12:30 AM
86IROC305's Avatar
This may sound like stupid question, but were is the proportioning valve located on a stock brake system (Is it that brass piece directly below the master cylinder ?). Rear disc brakes are new to me and I've never had to worry about this in the other rear swap's I've done....
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Old Feb 11, 2001 | 01:23 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
One difference is that the drum brake axle ends are bigger in diameter and won't fit inside a disc rotor without having it turned on a lathe. The proportioning valve is the aluminum block right below the master cylinder.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
