10-bolt 28 or 30 spine count?
Old Feb 11, 2001 | 08:39 PM
Get Blown ?'s Avatar
To the best of my knowledge my rear is still the factory original. With that said is there an easy way to tell of my rear has a 28 or 30 spine count? I have a chance to pick up a set of 3.42s w/ posi unit for 28 spine count dirt cheap and would like to not pass it up. Currently my car has 3.08s w/ a worn posi unit, on a drum rear.
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
The posi unit breaker.
Old Feb 11, 2001 | 08:48 PM
Bort62's Avatar
try 26 or 28 )
And it could be Either, A good Way to Check is to Count )
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Feb 11, 2001 | 10:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your 89 is in the transition time period. It's a good chance that it's 28 spline but it could also be the 26 spline. The only way to tell is to count the splines.
If yours isn't 28 spline, you can always buy a set of aftermarket 28 spline axles. They're only $125 each.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 11, 2001 | 11:03 PM
Thanks guys, while I was checking the archives I did not note what year was the cross over period. Don't know why I typed 28/30 instead of 26/28...
antman89iroc
36
Jan 31, 2016 08:42 AM
gta892000
Sep 16, 2015 12:40 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Fox118
Sep 1, 2015 04:07 PM
Eric2ndGen
Aug 31, 2015 11:30 AM
