9 bolt or 10 bolt?
Old Oct 19, 2008 | 10:43 PM
Gus68's Avatar
9 bolt or 10 bolt?
Hey guys!!!! Been doing jome junkyard crawling and was wondering how to tell the 9 bolt from the 10 bolt at a glance?? I know it refers to the bolts on the ring gear but the old 10 and 12 bolts had the same number of bolts in the cover. Do 9 bolts have 9 bolts on the cover as well??? Or is there some otherway to tell with out taking the cover off? Also I know of a rear end out of an 85 firebird with a 2.8 and auto that I could come and get, what would that have for gears??? I know its just a guess but what would it most likely have?? Would I have better luck finding deep gears in a v6 car or in a v8 car with auto or manual??? Just want to speed my junkyard searching!!!Thanks!!!
Old Oct 19, 2008 | 10:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 9 bolt or 10 bolt?
It's the number of bolts on the rear cover, not the ring gear.
A very quick glance of the cover can also tell.
A smooth cover is a 10 bolt
A cover with a rubber fill plug is a 9 bolt
A cover with a metal plug in it is a rare Dana 44.
GM produce 3 different 10 bolts over the years. 8.2, 8.5 and the 7.5/7.625. All 3 have 10 bolts on the rear cover but the rear cover is different shaped on each and none share anything similar.
An 85 Firebird with a 2.8 will have 3.42 gears.
Old Oct 20, 2008 | 06:05 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
9 bolt also has a lil "hump" in the middle of the cover where the ring goes
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
