ZF6 or T56???
Subscribe
Feb 9, 2001 | 02:57 PM
A guy has a '96 LT4 Vette ZF6 6-spd for sale. Question is: is it as easy to install as the T56? I can fabricate a tranny crossmember so thats no deal. Is it as strong as the T56? Work as good? I figured it would be just as good, but I thought I read somewhere that they were junk. Please help... BTW are they worth more or the same as a T56? THX Later
'91 GTA:
www.fbody.com/members/91WS6GTA
Reply 0
Feb 9, 2001 | 06:19 PM
A ZF-6 is 10times better than a t-56, they are a ton stronger than a t-56 and are nice and heavy to prove it. Ive read that they can be put in about as easy as t-56. That would be the ideal trans for a serious 6speed build up
Reply 0
Feb 9, 2001 | 08:13 PM
Do a seach on this board and you will find a not to long ago thread about this. ZBRA answered a few questions and has said what is a pain in the *** .
HTH
Reply 0
Feb 9, 2001 | 08:50 PM
I don;t recall many details, but I do remember it was a great deal more difficult, and expensive, than a T56 swap.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Reply 0
Feb 10, 2001 | 08:44 AM
There was a conversion kit that allowed you to use a T5 style clutch and bellhousing, I think that's what ZBRA did, however it's no longer made. Plus ZBRA used a tunnel mount torque arm (JESGter Torque Arm) since Vettes do not mount the torque arm to the tailshaft. Use the search button and look up ZBRA or ZF6 I know you'll find alot more information then I can remember off my head.
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
The posi unit breaker.
Reply 0
Feb 10, 2001 | 09:08 PM
I know there is something funky about the bellhousing bolt pattern being different somehow. You will need to use a dual mass flywheel. The trans is strong but relatively heavy. It's higher ratios are conducive to lower axle ratios like a 3.73-4.10. I would throw in a t-56 for simplicities sake. The aftermarket totally supports the conversion.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Reply 0
Feb 13, 2001 | 09:09 PM
https://www.thirdgen.org/messgboard/...ML/001035.html
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
Reply 0
Subscribe
