Trans not shifting when cold?
Old Oct 21, 2008 | 01:11 PM
Sooo_slow's Avatar
Car: 82 Z28
Engine: 327
Transmission: TH350
Ok, so this problem recently started within the last month.
TH-350 all stock, no shift kit. Bolted to a 327(if that matters).
B&M megashifter (3speed) with bracket and leveler kit and B&M 5 foot universal cable.
When vehicle is not running, I can cycle the shifter through all the gears and it is changing gears on the transmission. When running but cold, I cant get it to engage any gear, the rpm's lower slightly (maybe 200 or so) when I select a gear. But still not engaging in the transmission.
However, once it has warmed up quite a bit, it will shift into all gears smoothly and will rachet just fine.
I've tried re-adjusting my cable/bracket but to no avail.
Fluid level is fine.
What could it be, low pressure?
Any help would be appreciated.
Old Oct 21, 2008 | 03:54 PM
performabuilt's Avatar
Re: Trans not shifting when cold?
I would suggest that you check the fluid level
jklein337
Sep 19, 2018 06:23 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
