Can I swap the t56 and motor at same time
Old Feb 11, 2001 | 05:10 PM
AustinT's Avatar
I am putting In my 350 and I want to put the motor and the t56 at the same time. I know the t56 is a larger transmission. Has anybody swapped in a motor and T56 at the same time will it work?
Old Feb 11, 2001 | 05:16 PM
ede's Avatar
ede
i've done sbc and auto trans, th350s. i'd think it'd work for you with the manual. but not sure.
ICON Motorsports
1st & 3rd
Old Feb 14, 2001 | 10:25 PM
90FFBird's Avatar
I did both , but not at the same time. I don't see why it would make a difference if you did them together. The T56 is very close to the same size as the 700 trans. You won't have to change driveshaft lenth unless you use an aftermaket version T56. Just make sure you have all your parts before you start.
Old Feb 15, 2001 | 11:47 PM
82z's Avatar
82z
You shouldn't have any problems. The engine will fall in place and the trans nearly will. The aftermarket supports the t-56 swap very well.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
1984HO
Mar 19, 2021 11:59 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
