Just completed axle build-up
Car: Take
Engine: Your
Transmission: Pick
I recently built up a spare rear-end for my car. If you want to see what all I did, check out this link: 10-bolt build-up
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
that's great the "how to" questions get asked here every day. maybe someone will do a search and find this thread, or your link.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
I learned another method to set up the preload that in most cases will also put the backlash right on the money. Using the service spacer on the ring gear side and a bent shim on the passenger side we added shims to the ring gear side until the backlash was at .001-.003. Then we added a shim to the passenger side that would go in with pressure from 2 thumbs(spacer installed). We would take the size of that shim and add .010-.015 to preload the bearings. After measureing preload and using the equation you described would would add or subtract shim to get proper preload. Most of the time proper backlash will be established this way. Have you ever seen any problems due to ring gear runout? My instructor told us this is an important check but it doesn't seemm like it would be a problem as most people would be using new bearings anyway. What do you think? Variance numbers are based on a .045 pinion shim right? I must have slept through that part of class.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
dbrochard
Sep 19, 2015 08:13 PM
rudolphschenker
Sep 4, 2015 02:41 AM
