another stall question?
Old Feb 19, 2001 | 01:25 AM
burnoutrpm's Avatar
i was thinking of using a 2100 rpm stall and was wondering if with a 700r-4 tranny what makes it lock up??? i switched from tbi to carb and had the lockup feature manually but then got lazy and dont use it anymore. so i was thinking with my new converter(stall) to get the cheaper one wiothout lockup!?? bad idea? just wondering since i dont use lockup anyway?? is it in the tranny itself? or in the converter only??? its a 89 700r-4.!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 19, 2001 | 10:40 AM
The ODB's Avatar
the lockup feature is built into the tranny and converter. It is much to your advantage to keep the lockup feature.
It is a simple procedure for a tranny shop to install a pressure switch in your valvebody to control TCC lockup. All you have to do is supply 12V switched ignition power source to operate the solenoid (comes on with ignition key). The converter will lock and unlock on it's own via pressure at that point.
I run both the pressure switch and electronic solenoid in my tranny for more control.
If you're going to go higher stall then go at least 2400 with a Vigilante 9.5". It will increase performance while operating just like a stock converter. The Vigilante also has a larger heavy duty clutch that can be engaged at full throttle.
My camaro gains 2.5 MPH trap speed by using the lockup feature.
ODB
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
C409
Sep 1, 2015 03:42 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
